Freezer compartment not freezing at the top.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Freezer compartment not freezing at the top.
  • #20546
    mccaffr
    Hi, I have a Scandinova FF6745D, when we came back from holiday it seems that we have had a power cut and the food within the freezer has defrosted. We have read the manual and swithed the freezer off for a few hours and tried again, cold air is blowing out of the back inside at the bottom. I have removed the back cover and can see that the fan is not rotating. Should it be? Would you know what the problem might be? I do not really want to replace it, it is 8 years old but the fridge is still working and have not had any problems other than this now. Please can you advise, URGENT, melting food!
    #187426
    Re: Freezer compartment not freezing at the top.
    was there a large build up of ice behind that rear panel? If there is this can disturb the airflow and indicates a defrost problem. The fan does not always run, especialy after powering up and may even be controled by a door switch. If there is a build up of ice, defrost completely and then try again but problem may re-appear in a few weeks.
