freezer in garage
  • #33442
    acrt
    Hi all
    I’m after some advice on having a freezer in the garage. I have recently moved the washing machine and tumble dryer out there. After the washer dryer died.
    It is protected from frost as it has a heater that keeps it above 5°C.
    My only concern is although it has had the roof and walls insulated it can still get quite hot in summer. Last year on a couple of days it reached 35°C. Would a Bosch GSD 12V20 be ok with this.
    The only other option is to put it in a cupboard under the stairs.
    Thaks
    #238733
    Dales-Electronic
    Re: freezer in garage
    I think you will get away with it as you have an installed heater that maintains the temp above zero.
