Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Freezer relay
- This topic has 22 replies, 4 voices, and was last updated 6 years ago by
Jackamus.
March 31, 2020 at 9:55 pm #467200
Moderatoryep that looks ok
April 1, 2020 at 7:40 am #467201Jackamus
ParticipantCheers I’ll give it a go and let you know what happens.
April 1, 2020 at 9:17 am #467202Jackamus
ParticipantI wired it up according to my drawing and nothing happens except it hums for about 10 secs and stops.
One of the things I read about replacing a relay is that you should replace the overload as well. What do you think?April 1, 2020 at 9:31 am #467203SAMURI
ParticipantCompressor seized. Not a relay fault , It will need a new compressor but as it’s not an expensive freezer it would be beyond economical repair.
April 1, 2020 at 9:46 am #467204Jackamus
ParticipantIs there a way to check the compressor? I measured the resistance between the 3 pins and they agree. See my original messages.
The new compressor and replay would cost £119 but I can but a new decent Hoptpoint for £199.
April 1, 2020 at 9:47 am #467205electrofix
ModeratorSAMURI wrote:Compressor seized. Not a relay fault , It will need a new compressor but as it’s not an expensive freezer it would be beyond economical repair.
totally agree and we said that a while ago
you need to give up, its just not worth the time and effort. I know it can give you a feeling of failure, as enginners we have all been there, but there comes a time to stop.
if you worked in fridges and had a spare compressor lying about or take one of another unit then regass it, then maybe it would be worth it to you.in this case you are in the same position i would be in because i cannot change compressors either
April 1, 2020 at 9:50 am #467206electrofix
ModeratorJackamus wrote:Is there a way to check the compressor? I measured the resistance between the 3 pins and they agree. See my original messages.
A compressor is not only electrical, it is a moving pistion in a cylinder a bit the same as a car engine. In you case the motor side of your compressor is probably fine, its the mechanical piston thats siezed. So no measurement in the world is going to detect that
April 1, 2020 at 9:55 am #467207Jackamus
ParticipantFair enough Dave. I’ll concede defeat and see if it possible to buy a new one. Thanks for all your help and advice.
