Freezer Wobbly !!
  • #9312
    Hiya, hope you can help me and my freezer. I inherited the scandinova about 4 years ago, we think it must be 6+ years old in total. My fridge works just fine, but recently my freezer has started to throw a wobbly regarding the temperature. I have put a thermometer in there and one minute it shows -20 then I go again a few hours later and it can be +5 and the ice cubes have melted !! There is a rocker switch on the top that you can see when you open the fride compartment which is either set to ‘S’ or ‘O’ – seeing as I have never had any instructions with this appliance I presume the ‘S’ if for superfreeze ????? So its normally on ‘O’ but I have now turned it to ‘S’ and the freezer hs kicked in again. Do I keep it on’S’ or do I start looking for another freezer ??? PLEASE HELP as I’m 3 months pregnant and need to be organised. XX
    Sorry – forgot to mention the model number – FF6745D
    Any help would be appreciated.
    #133454
    Dave_Conway
    Re: Freezer Wobbly !!
    OK, taking in to account the time scale since you posted the query.
    What has happended since the switch was left on “S” ?
    #133455
    Hi Dave, thanks for replying considering its bank holiday weekend. Just been to check and the temperature is -22.
    The rocker switch is still on ‘s’.
    #133456
    Dave_Conway
    Good, it sounds like it’s just the thermostat then as it proves the system is working so it shouldn’t prove too scostly to put right.
    The S switch is fast freeze which basically bypasses the thermostat and makes the unot run continuously (not recommended for extended periods).
    Have a look for an engineer in repairs@ and the directories, failing that, pop up your postcode and I’ll see if I have anyone I can recommend near you.
    #133457
    Thanks Dave, I like the sound of it not being too costly 😀
    Can you give me any idea on a rough cost just so that I am slightly prepared, I would be very greatful.
    Postcode is S81, Worksop, Notts.
    Thanks again,
    Sarah
    #133458
    How long do you recommend I leave it on fastfreeze in any one time period ?
    And how long do I switch it back to ‘normal’ for, obviously keeping the door closed as I dont want unfrozen food 😀
    #133459
    Dave_Conway
    OK, here’s a link for a repairer:
    http://www.ukwhitegoods.co.uk/modules.p … ent&tid=57
    Costs vary to be honest, between £60 and £80 as a *very* rough guide.
    Don’t leave it on for too long, two or three hours then switch back to normal for a two or three etc etc. Overnight, leave it off, it should stay frozen for 12 hours as long as the door seal is OK.
    #133460
    Dave, has anyone ever told you that you are a living legend ?
    THANKYOU SO MUCH for all your help and advice, it is very appreciated.
    I will visit the link you sent me and get something sorted sooner rather than later.
    Enjoy the rest of your weekend 😀
    Sarah
    #133461
    Dave_Conway
    Lilbear wrote:Dave, has anyone ever told you that you are a living legend ?
    Yep, loads of times :rotl:
    Not really, you’re more than welcome 😀
