Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Freezer working, fridge not.
- This topic has 8 replies, 2 voices, and was last updated 6 years, 2 months ago by
Pif.
January 16, 2020 at 11:47 pm #97056
Pif
ParticipantAeg fridge freezer troubleshooting.
Freezer works just fine, fridge doesn’t.
Before this happened, fridge started froze on the back, like a lot, then after one month, stopped working all together. Freezer still working fine. Model s73400cnso. What should i check first?January 17, 2020 at 12:38 am #465950kwatt
Keymasters73400cnso is not a valid number.
Can you get the product code from the rating plate, might be marked PNC so we can see what it is?
January 19, 2020 at 5:03 pm #465951Pif
ParticipantProd number 925033735-02
S number 21040099January 19, 2020 at 5:16 pm #465952kwatt
KeymasterCheck the fridge thermostat.
If that’s okay then it’s a system problem and you won’t be able to DIY it.
January 19, 2020 at 5:23 pm #465953Pif
ParticipantWhere does the termostat should be, is it behind that knob that you turn from 0 to 6?
It seems to cool down a little now, but now my much. Freezer continues to cool down ok.January 19, 2020 at 7:39 pm #465954kwatt
KeymasterYes, it’s there but, asking that question you’re probably not up on how to check them.
How they work is explained here: https://www.ukwhitegoods.co.uk/help/fix-it-yourself/refrigeration-self-help/3658-fridge-and-freezer-thermostats
January 19, 2020 at 10:21 pm #465955Pif
ParticipantI opened it up, but a wire is straight soldered to what i think is the thermostat, and then the other end goes inside a small hole in the fridge with no access to disconnect it. How can i find a schematics to this , or where?
January 19, 2020 at 10:49 pm #465956Pif
ParticipantWell, i don’t want to check them, cause then, i will have to learn how, and then spend money on gear that i will probably not need again. I just want to change thermostat or whatever part might be at fault, cause parts are cheap, before i threw it away and buy a new one, if i dont find whats wrong with it. Will be happy to find the schematics, to see where the parts are, and change the ones i think they are causing the fault, one by one. I dont want to call someone to come to fix it cause it will be more likely he wil charge me 140 200£, wich is the starting price for a new fridge. Willing to spend 30 50 in parts and give it a try, and if it doesent work, then to get a new one. I have a spare one, and i do like fiddling with this kinds of things, when i have time.
January 21, 2020 at 10:46 am #465957kwatt
KeymasterHonestly, at that point, you really need a pro-repairer.
I think it may well be a refrigerant system issue but the thermostat is this one, it’s a £30 odds gamble:
https://shop.ukwhitegoods.co.uk/2262348200-fridge-freezer-thermostat
