Home › Forums › Public Support Forums › Spare Parts Help › Fridge Freezer: Fagor FIC-541UK/1 serial No: 10-11-00223
- This topic has 2 replies, 3 voices, and was last updated 10 years, 8 months ago by
philwalton.
July 24, 2015 at 5:36 pm #85638
philwalton
ParticipantHello there!
Just looking for a little help with sourcing a kit to re-install the Fagor fridge freezer I have inherited. It`s designed to be integrated but did not come with any of the parts to install it into the cupboard. Do you happen to know of such a kit?
Many thanks in advance!
Kind regards,
Phil
January 7, 2016 at 9:11 am #429164ivanlsmith
ParticipantRe: Fridge Freezer: Fagor FIC-541UK/1 serial No: 10-11-00223
To install freezer is the most easiest thing to do,as we just have to plug it into a wall which is having electrical socket.But it is not the only task which is done for installation of freezer.Freezer is such a product of kitchen that a has long life so its installation should be done properly and carefully.Once we keep the freezer and we have filled it with foods ,its difficult to change its position or allocate it again somewhere else.So we have to allocate on the best place where it can be placed for a long term in good condition.We need a cool,dry place along with a electrical socket near freezer and the room should be big enough to open the door of the freezer properly and height of the freezer should also be considered.Keep freezer in a cool place because in cool place it works more efficiently and in heated place freezer works forcefully to maintain its 0 degree Fahrenheit or less than it.The freezer which works inefficiently will give you a problem of costing more for energy it consumes.
If you have a old freezer also then you can keep your new freezer only for extra food items and we can keep this freezer away from kitchen. But if you are having only one new freezer then you should keep it in kitchen.
Mainly there are 2 types of freezer: chest and upright freezer.These both are having their own benefits.Upright freezer mingle more simply than chest freezer.Upright freezers are available in automatic defrost.Upright freezers are n more reliable than chest freezers.
Freezers can also be positioned in utility room, garage, kitchen, basement and laundry room.When you place the freezer outside you should keep in mind that weather temperature should be suitable for the freezer.January 7, 2016 at 9:31 am #429165kwatt
KeymasterRe: Fridge Freezer: Fagor FIC-541UK/1 serial No: 10-11-00223
Spam link removed from the post above, please do not post that again or your account will be deleted and the email flagged as a spam one.
