Fridge freezer for a garage pls?
Home Forums Public Support Forums General Enquiries And Questions Fridge freezer for a garage pls?
  • #83232
    joeyjoey
    Evening all
    I’m in the process of buying a replacement fridge freezer for my parents, it’s to replace a 20 year old faulty one in their garage.
    Having read on here & other websites it’s come to my attention that modern FF aren’t designed to be placed in rooms that are prone to temperatures below 10 deg C and that the freezer can start to defrost due to the low temperature in that room. Is there a FF that can be stored in a garage which basically gets as cold as the temperature outside?
    My parents old FF never gave this problem.
    Thanks all.
    Joey
    #422131
    Re: Fridge freezer for a garage pls?
    No not at all. Modern fridges are controlled by electronics, it ain’t gonna work unless you heat the place best part of 5 – 6 months a year. Try to keep hold of your old one is my advice or find space in the house!
    #422132
    lee8
    Beko produce fridge freezers to work in temps as low as -15 degrees using there freezer guard technology.
    http://www.beko.co.uk/Innovations/FreezerGuard
    #422133
    joeyjoey
    Thanks for the replies folks.
    The Beko seems ideal but I’m hesitant to buy what with the recent negative press about some Beko products setting alight?
    joey
    #422134
    lee8
    Beko fridges are safe. Electrolux group have had some serious issues across their range, a huge PR dept ensures media coverage kept to min.
    You’ll find the Beko a perfect fit.
    #422135
    joeyjoey
    Thanks lee8 that’s reassuring.
    I just read that the Beko would be OK in a garage(not designed for it they say), the freezer will function OK but the food in the fridge will freeze at the high minus temperatures. I suppose its a give & take situation, its a second fridge so they’ll have to keep delicate fridge foods in the kitchen Fridge freezer.
    joey
