fridge freezer lg GR 349SQF
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum fridge freezer lg GR 349SQF
  • #80214
    2run2fells
    How do I replace the thermostat on an LG fridge freezer GR 349SQF,
    I am thinking that a faulty thermostat is the reason that I get a slab of ice building up on the bottom of the freezer under the lower draw, otherwise the fridge and freezer seem to work fine.HC
    #412112
    Re: fridge freezer lg GR 349SQF
    More likely that the defrost drain is blocked. Defrost the freezer fully for 48Hrs and then at the rear of the appliance in the centre just above the water collection container on top of the compressor you will see a black piece of rubber pull it off and leave off. This rubber gets sticky and stops the water from draining away.
    Bryan
