Re: fridge/freezer location
Hi lowrider
If you type refrigeration AND outbuildings into the search bar here there is quite a lot on this very subject.
The following info on climate classes from one of those threads may help.
don wrote:Hi
All refrigeration is produced to a climate class. Climate class indicates what ambient room temperature an appliance is designed to operate in. N=’normal’ +16ºC to +32ºC; SN=’sub-normal’ +10ºC to +32ºC; ST=’sub-tropical’ +18ºC to +38ºC. The appliance will not cool correctly if the room temperature falls outside the stated range for long periods.
Not all manufacturers disclose this info in their sales material so contact may need to be made directly to clarify by model number.
HTH 🙂
Don
HTH 🙂
Don
