Fridge freezer problem in Malta
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fridge freezer problem in Malta
  • #63399
    Mike.Gozo
    Samsung RS21DCNS1/XEU(A)
    Hi, I live in Gozo (small Island near Malta) so no service engineers here!
    OK. Freezer was only chilling to -10. On investigation freezer element has large build up of ice. My local appliance repair man switched off unit and defrosted ice with hair dryer. When switched on diagnostice light on freezer side r/h digit bottom right icon was flashing. Reset unit with the top 2 buttons and unit fired up OK, however, within 5 days fault reoccured and freezer woul dnot attain more than – 10 or so. We noticed the fan inside the freezer was not running so the engineer conected the fan to a direct 12 volt supply pack and the fan worked OK. Now, the freezer appears to be operating much better. The temperature is now on – 21 degrees, I think that is a good sign ? Perhaps what ever controls the fan is at fault and is it replaceable by my available engineer. He normally works on pre war frigdes I think !! Any assistance would be greatly appreciated. I have also emailed direct to spares@ UK. Thank you in advance Mike.Gozo.
    #353664
    Re: Fridge freezer problem in Malta
    if its a 12v fan there must be a printed circuit board controlling it.
    fimd the board and look for damage
    Mike.Gozo
    Hi Dave, Is the defrost sensor suspect with these symtoms? The reasoi I ask is the digital display showed the second digit (freezer) right hand bottom was indicating a fault. Question..I the sensor the blue thnigy on the back panel? If so I have checked the connector to make sure it’s well plugged in. Sorry about this problem but I need to diagnose the fault and then hopefully obtain a remedy. Thanks Mike.gozo
    #353666
    i do not know fridges that well mostly do washing machines etc but if you look up a member called R600a he has a lot of knowledge with samsung fridges and may be able to help
    PM sent mike
