Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Fridge Freezer stopped working
- This topic has 13 replies, 4 voices, and was last updated 16 years, 10 months ago by
aks_72.
June 15, 2009 at 10:02 pm #46404
aks_72
ParticipantHelp needed 😥
I have a Hotpoint FFM90A Frost free fridge freezer.
It was working fine, Until I moved it, Due to the hieght it was placed sideways in the van for approx 20 minutes.
It was then stood for about an hour before we turned it on.It now does work, its not blowing any air through the vents both at the top and the bottom section plus it is warm inside and it keeps bleebing, it been on for over 24 hrs,
I removed the false back cover inside the freezer, and the silver coils (sorry don’t know the techincal term) were cold and slightly iced, but I noticed the fan wasn’t working. Could it be the fans failed and how do I check it ? Or is there still oil in the pipes? :rolls:
Please Help?
June 16, 2009 at 12:33 pm #289221spimps
ParticipantRe: Fridge Freezer stopped working
The fan won’t cut in until the evaporator eaches a certain temperature,the evap would be evenly and heavily covered in frost if the fan had failed totally.
Sounds like you have a system restriction maybe due to some oil not having settled back causing partial blockage or could be oil in condenser causing poor cooling of rerigerant .
Normally leave off for a minimum of 4 -5 hours,it can also depend on which side it was laid.
Try leaving off for 24 hours in a warm room and see if that will pursuade the oil to return,if it’s no better after that then you could be in expensive trouble.
UNPLUG FIRST !!
Also check no blockage of dust etc underneath,there will also be a fan pulling air through that so worth a look.June 16, 2009 at 2:43 pm #289222aks_72
If it Helps
when the fridge was moved, and put into the van the compressor was at the top facing down, and so were the pipes,
June 16, 2009 at 2:52 pm #289223kwatt
KeymasterRe: Fridge Freezer stopped working
It’s probably blocked then, especially if you ran it less than at the very least under eight hours after it was moved.
It may be able to fix it but, equally, it may well be choked internally in which case, it’s a scrapper.
June 16, 2009 at 3:07 pm #289224spimps
aks_72 wrote:If it Helps
If you lay one down on it’s alwasy keep the compressor end/bottom lower than the top of the fridge otherwise the oil which is very light will find it’s way into all the pipes it’s not supposed to be in, never to return.
Chances of recovery are slim to zero,sounds like it’s scrap.June 18, 2009 at 9:25 am #289225aks_72
Hi Again
If the fridge does not work when i switch it back on as it is still off.
Had it off now for approx 48 hrs now, is there anything a engineer can do ? As sum one suggested i have it vacuum syphoned and new gas replaced.
Can this be done?June 18, 2009 at 10:16 am #289226kwatt
If the internal capillaries are blocked then it is a 50/50 on whether it can be cleared or not. But yes, it can be vac’d down to see if it will clear but, if it doesn’t work then you’ll still have the bill for trying I’d expect.
If you look at the rating plate and it has R134a or R600a gas in it, I wouldn’t even bother trying in all honesty as it is most probable that it’s choked solid from what you’ve told us.
It’s not a DIY job as it’s gas work, you cannot do this yourself without specialist equipment and training and I’d figure on around about the £100 mark to attempt it.
June 18, 2009 at 3:13 pm #289227spimps
System would have to be evacuated,flushed,compressor would need firther oil,evacuated again and then regassed,would it work?not gauranteed.
Very time consuming and as KW says £100 plus.June 18, 2009 at 4:03 pm #289228aks_72
Thank you for your prompt replies KWatts ans Spimps,
I will switch the fridge on later, and leave it on for 24 hrs, and see if it works.
If it doesn’t work i’ll decide on whether its worth repairing or getting a new fridge.
thankyou.June 20, 2009 at 7:46 pm #289229aks_72
ParticipantRe: Fridge Now Not Cooling
I have switched the fridge on been running now 48 hrs.
The temp of the freezer was 18 c, it gradualy dropped to -2 after about 12 hrs.The problem i’m getting is that the top of the fridge is still warm and the bottom does not cool more than -2.
The fridge then auto defrosts and the temp rises to 6c and it gratually drops to -2 after a few hrs.
I opened the false panel in the freezer section there are two tube like thermistors one with a red band and one with a yellow band these exit through a hole in the back of the fridge and disappear.
So i dont Know How to Check These?I have not seen the fan cut in yet but then i’ve been told this wouldn’t cut in till the temp reaches -6c is this correct.
So what is wrong with my fridge ??
June 20, 2009 at 8:23 pm #289230helo_75
Participantits got a blocked system
when will u read what people have said?
June 22, 2009 at 2:48 pm #289231aks_72
ParticipantRe: Bypasiing the fan?? Pro’s & Con’s
Today I finally got an enginneer to look at the fridge
After about 10 minutes checking various things within the wiring plug,
He reported that the fan was not working, and the fridge was not cooling properely. The fan was not at fault but the electronic circuit board sending power to it was,
To fix it properely,
A new board was needed but he could bypass the board and get the fan to run.Therefore what are the pro’s and con’s of having the fan by passed? if any.
Was he correct saying my board at fault ?
I have not had any repairs done yet?June 22, 2009 at 3:22 pm #289232spimps
The fan doesn’t run until the evaporator drops to a preset temp which it is not acheiving so it won’t run,is he aware of that?who knows?
From what you have said the system appears blocked.
Is the engineer right?he could be.We are trying our best to give a considered opinion on your description,then again he may not be right.June 22, 2009 at 3:27 pm #289233helo_75
Participantby pass the board so the fan will work?
yep and freeze everything in the fridge
that is of course if hes right… blocked system me thinks
