Re: Fridge Freezer thermostat capillary bulb position
That seems wrong for this model. There are two plastic panels forming the rear of the freezer compartment that lie in front of the evaporator. Directly in front of the evaporator is one plastic panel holding the fan and the thermostat capillary was threaded through what looks like a purpose made hole in this. A second plastic panel about an inch further forwards hides the fan and then forms the rear of the freezer compartment with guides and holes arranged to direct the airflow. The air falling or rising from the fridge compartment feeds into this space between the two plastic sheets. The thermostat capillary bulb apparently should be placed somewhere in this space between the two panels but it is not clear where that should be.
