Fridge-freezer won’t freeze in cold weather – why?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fridge-freezer won’t freeze in cold weather – why?
  • #66919
    BrianT
    We have a second fridge-freezer which is technically outside, although sheltered from the elements.
    When the weather gets cold, temperatures down to single figures (not even freezing), the freezer stops freezing and anything in it ends up thawing. The fridge keeps working although that too seems not to be as cold as it should be.
    Is there anything I can do about this? It did it last winter too but started working normally once the weather warmed up in spring.
    #365629
    don
    Re: Fridge-freezer won’t freeze in cold weather – why?
    Hi Brian
    This is an ongoing issue every winter with fridge freezers either in sheds / garages or unheated conservatories. In your case as it’s technically outside the only thing you could do in this instance would be to bring the appliance indoors during the cold spells.
    A full article here in our advice section explains the issue in greater detail.
    HTH 🙂
    Don
    #365630
    This article explains it:
    http://www.ukwhitegoods.co.uk/help/buyi … ouses.html
    BrianT
    Cheers gents. That’s helpful. At least I know it’s not a malfunction as such. Beery christmas!
    #365632
    spimps
    Apart from moving to southern Spain,not much you can do although keeping a 2ltr milk bottle and fill with fairly warm water,pop it in the fridge every morning/evening giving it something to do and it will probably help keep it ticking over.
