Fridge Freezers with similar problems
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fridge Freezers with similar problems
  • #26561
    pauly
    I have two fridge-freezers, both Candy, both with similar problems. The freezer will freeze to around -30, but the fridge stays at room temp. I’m assuming that this is due to gas loss, but any advice would be welcome.
    #210608
    Dales-Electronic
    Re: Fridge Freezers with similar problems
    Model No’s and serial no’s please
    #210609
    pauly
    OK, scrapped the Candys, but now have the same problem with an Indesit, model# RG2190, ser# 209202141. I thought it might be a generic fault with fridge freezers, so apologies for no serial #s.
    Any assistance is greatly appreciated,
    #210610
    Hi Pauly,
    No it’s not a generic failure and could be attributed to several reasons dependent upon the system employed (i.e. forced air or falling air) and how or component failure which would typically be thermostat/thermistor, PCB, compressor. There’s also the posibility of, on a forced air unit, of a fan failure, either blocked or mechanical/electrical failure. Then there’s changeover valves, a favourite.
    Sorry, it’s too open a question to narrow the field for you with regard to a generic failure.
    I’m not familiar with the Indesit model, but knowing Indesit it’s doubtless a lower end product, so I’d be looking for a stat, changeover valve or possible PBB/thermistor problem if it’s electronic.
    Hope that helps.
