Fridge getting too cold?? Indesit BA-12
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fridge getting too cold?? Indesit BA-12
  • #48101
    mrsail
    Hi, I have recently bought a second hand Indesit BA-12 fridge freezer.
    Since turning it on I have the following problem:
    * On turning on the fridge gets very cold and ices up….
    * when you switch the temperature controller to “OFF” then back on again (to minimum) you can hear the fridge stop and after a while will come back on…. it then goes to a reasonable temp..
    * The fridge then works for a week (max) and freezes over again until you repeat above?
    Is this the thermostat? or would it be something else?
    If this is the thermostat is it easy to replace if I bought the part? is there any websites that show the procedure?
    Any help appreciated as a novice on this!
    thanks
    J
    #295572
    Re: Fridge getting too cold?? Indesit BA-12
    Moved you to correct forum. 😉
    #295573
    mrsail
    whats the correct forum?
    #295574
    don
    mrsail wrote:whats the correct forum?
    For your enquiry the Refrigeration help and support forum.
    If you click on forums in the navigation bar on the home page you will see that there are different forums for each product group. Keeps the whole site simple and ensures the right people who may able to help you see each topic clearly.
    HTH 🙂
    Don
    #295575
    You posted in the ‘General’ questions forum originally. 😉
    #295576
    spimps
    mrsail wrote:Hi, I have recently bought a second hand Indesit BA-12 fridge freezer.
    thanks
    J
    Is it freezing the stuff in the fridge?
    Empty the fridge and remove shelves,you will see a thin wire type looking device fastened to the back wall of your fridge.
    Either an oblong clamp with two screws or a round one will hold it to the wall.
    Make sure that is fixed firmly as it is the phial from the thermostat which sense the temperature.They can become dislodged.
    BG
    #295577
    mrsail
    Sorry for long reply, only got round to having a look tonight.
    After doing as you said taking all the shelves out… It revealed no hatches or areas where the thermostat could be…. The only holes/openings was the drainage hole and light at top which I even opened??
    Would there be any other place the thermostat could be?
    Thanks john
