Hello peoples
I have a fridge freezer with a nasty dent and crack in the fridge liner (floor). What do we find best to bond and seal the thing up? In the past I have used poly pipe pipe weld, but I don’t have any at the moment and it does smell quite high and can be very difficult to get a smooth finish.
Obviously I will be pulling the dented end up and level with the rest of the floor, but I will need to bond it closed.
Cheers
You might be better to look at a plastic welder, I looked at them a while back but never got around to getting one as I didn’t have a heap of need for it but, they can be used for things like that and may be better than a cement.
Plus, I expect there’s other uses for them as well and they’re not expensive really.
