Fridge not cold
  • #19369
    skip
    Hi need some advice/help, I have a LEC fridge/freezer Model N215 Serial 5b002338 the problem is that the Freezer is working ok but the Fridge is not getting as cold as it should, It has what they call a Turbo larder when you opened the door you could feel the cold air coming out, not any more there is still a slight chill due to the section inside on the back that still gets iced up
    Regards Skip
    #182848
    Re: Fridge not cold
    try to turn the appliance off for 24 hours with both doors open and then switch back on.
    If the same fault reocurrs then you have a defrost problem which will need a engineer visit.
    bryan
    #182849
    pharris
    Re: Fridge not cold
    If you cannot feel to “Turbo” when the door is opened, maybe the fan is not going.
