Guys.
We have a stand alone fridge at work, with a small freezer box built in to the top. Probably large enough to hold 2 loaves etc.
I can put a loaf in the freezer box and it will freeze solid.
Put milk in the fridge door and it’s never chilled enough.
I have a very cheap digital thermometer, so can’t rely on the accuracy 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
Using said thermometer, the fridge compartment isn’t very cold and only seems to be getting down to 12 degrees centigrade, where as the freezer box is getting down to at least minus 10 degrees centigrade.
All the door seals seem intact.
The internal stat is up to max.
The compressor sounds to be running.
Any ideas
