Fridge thermostat
  • #46518
    geoff1
    I have a commercial upright chiller unit which has a faulty thermostat. Can any one recommend an alternative to the one fitted which is a Danfoss 007B0032L
    It senses air temp just in front of the circulating fan fitted at top of chiller above evaporater.
    Temperature ratings on it are 15.7/4.0 and 11.2/-2.00 or may be 15.7/11.2 and 4.0/-2.0
    Geoff
    #289852
    Re: Fridge thermostat
    Got this off the web. Hopefully it may help. You’ll need to do a bit of work to untangle it though.
    pdf Invensys Temp control specs (Note temps in fahrenheit 😯 )
    Ranco have always been very helpful when I have rung them but last time was ten years ago. (01752)724277. Technical support line was then 0845 130 7722.
    Mike.
    #289853
    johnsdad
    sounds like danfoss No. 8 stat kit, or ranco VB7 might be right?
    #289854
    geoff1
    Many thanks both for reply. will give it a go tomorrow and let you know
    Geoff
    #289855
    geoff1
    Thank you.
    VB7 Thermostat was spot on.
    Geoff
    #289856
    johnsdad
    happy to help
