Fridge Thermostat for Scandinova 7054 Fridge/freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Fridge Thermostat for Scandinova 7054 Fridge/freezer
  • #24935
    Scan
    The fridge thermostat only works after sharp application of the wrong end of a screwdriver! There is no “click” as it is turned from min to max unlike the Freezer control which has 2 positive clicks. The switch unit is made by Danfoss with lots of numbers stamped on the holding case. So the question is:
    1. Can I replace this by isolating, removing connections and sliding out tube and sensor then relpacing.
    2. Where can I purchase the relevant part.
    3. Are there any other checks I should make to prove this assumption is correct.
    I would rather pay for the parts than replace an otherwise excellent fridge freezer.
    thanks.
    Scan
    #203891
    Fairdeal
    Re: Fridge Thermostat for Scandinova 7054 Fridge/freezer
    Do you mean fridge and freezer have seperate thermostat?
    Is it cooling properly, becuase if it is not cooling the thermostat will not click.
    The thermostat will have a K?? no like K59, K50 etc etc on the side
    Find that out and let us know
    Regards
    #203892
    clivejameson
    The stat can be checked with a meter by checking for continuity between terminals 3 and 4 when in the ‘on’ position. Being a Danfoss stat the only number on it will be a long one OB*********** but these are simply known as a kit 3 stat.
    Have a look at Shop@ for a replacement, if no luck then an email to Dave_Conway on spares@ukwhitegoods.co.uk will sort it.
    Alternative stat that will do the job is a Ranco K59 but it needs a longer capillary rather than the standard one (VT93 rather than VT9 IIRC?)
    #203893
    helo_75
    ooohh dont put a kit 3 on that.. they cut in too early
    only a genuine vestfrost one will do!!!
    #203894
    Scan
    Thanks everyone. Will digest these points and reply.
    Scan
    #203895
    Scan
    Previously this fridge worked intermitently.
    Have fitted replacement VT93 thermostat to fridge part of Scandinova fridge /Freezer.
    Have had it running for a few days and it does not swith off.
    Tried it at various settings.
    Connections are 3-BR live, 6/2-BL to compressor, 4 BR Common.
    The capillary went in with no problems and is held by the plate onto the back panel within the fridge. There are no kinks I am aware of.
    Switching on the thermostat brings on the compressor.
    Any suggestion or more information I can provide.
    Scan
    #203896
    clivejameson
    The problem is you’ve connected the new stat up the same way as the old one! Ranco stats have a different numbering system (really helpful)…the live feed should connect to 6, the compressor to 4 and the common on 3. If you look in the box that the new stat came in, often there is a wiring diagram for reference?
    Once again, plug out before doing anything :zap:
    #203897
    Scan
    Thanks Clive and to everyone on the forum who helped.
    Changed over the browns and all working.
    Scan
