Re: Fridge Troubles
The reason you got it cheap at an auction, I expect, is that it’s bust. 😉
The owner manual will not help you with the problem I don’t expect as it sounds like a thermistor, thermostat or electronic controller failure as it’s overfreezing in the fridge. But, TBH, that’s just a guess without knowing more.
It looks as if it was only produced through 2006 so I doubt there’s any warranty on it now, you would need proof of purchase for Service Force to honour any warranty at any rate.
Hope that helps.
