Re: Fridgemaster Fridge freezer
OK these chinese thermostats are abit weird in that if you turn them right up they act ask if you have switched them to fast freeze. Assuming from what you say that your unit is cooling its probably the thermostat that is faulty. If you can get it out to look at it (power off please) and let me have the wd number on the side of the thermostat we should be able to help you out. The genuine Fridgemaster part number is 140131 which you can source from our shop on this website if you are in a hurry.
