Hello,
My Frigidaire 2422A is icing up on the back and the compressor running all the time.
So, after checking the discharge hole on the back and finding nothing, went to replace the Thermostat as most probable cause of the icing.
Looks like Frigidaire themselves don’t have the part in stop. So decided to dig into Thermostat science
The original fitted thermostat is WDF25K-921 manufactured by jiujang autocontrol. According to the website, it is a K59 equivalent with cut in 3.5 and cut off -15 and -25. Close enough to a standard K59 VT9…. i thought
http://www.jj-ht.net/en/productshow.asp?id=351
And so, today got a Ranco K59 VT9 and fitted it in. No luck… still icing up, compressor running all the time. Knob on “1” position…..
What am I doing wrong?
Should I fit a VXO instead?
(To be honest, -15 seems a very low temperature to cut off in a fridge where the thermostat capilarity is attached to the back wall)
