Frigidaire FRE216A Fridge/Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Frigidaire FRE216A Fridge/Freezer
  • #91580
    michaeljohn
    Can anyone help, have the above model Fridge/Freezer that has developed the following problem. Apologies for the less than specific description for the following as I cannot obtain a useable diagram of the unit lay out ? When viewed from the front and fridge door open, in the left hand corner by the cabinet drain, a large block of ice has formed (formed over a short period of time. ) On the reverse side of the unit there is a large cold wet patch relevent to the cabinet ice block position. I cannot see where (presumably) the condenser is
    situated to pinpoint the source of the problem so is there a leak ?
    regards,
    mike.
    #448637
    captaincaveman1
    Re: Frigidaire FRE216A Fridge/Freezer
    possible insulation breakdown within the cabinet. It wont be a leak and the condenser on these is hidden within the insulation.
    #448638
    michaeljohn
    Thanks captain for your prompt reply, sounds about right as may be an insulation breakdown as I reckon if it had been a condenser leak it
    would be hot.
    regards,
    mike.
