Frigidaire Freezer FRF170FF
  • #62353
    larry
    please can anyone help? This freezer seems to run ok and gets the temp down to -18 then the compressor turns off but the alarm light stays on and the display numbers stay flashing reading the instruction book it should stop flashing when desired temp is reached but why the alarm light is staying on i can’t think i’d be grateful if anyone has any ideas,Cheers Larry.
    #349801
    Re: Frigidaire Freezer FRF170FF
    The defrost sensor will need to be moved and the appliance fully defrosted.
    Bryan
    #349802
    larry
    Hi Brian thanks for the speedy reply, you say to move the defrost sensor do you mean to just reposition it .
    #349803
    ELDAR59
    hi larry, if there’s no problem with temp inside the cabinet, then just hold the superfreeze button in until it beeps. then press it again until the superfreeze indicator light goes out.
    this will stop the indicator lights flashing.
    if there’s a temperature problem inside the cabinet, then it’s more than likely you’ll have to move the defrost sensor to the top of the evaporator and fully defrost.
    this is obviously assuming that all the components on the defrost circuit check out ok.
    cheers.
