Frigidaire Fridgemaster F/F MTRF222 Stat?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Frigidaire Fridgemaster F/F MTRF222 Stat?
  • #37499
    laurenceuk
    This machine runs continuously and is freezing up.
    The stat it utilises is not one I have seen. The tags are marked L-C-H and
    seem to be of Chinese origin.
    Can I use a VT9 and what tags do I fit to which from the original to the VT9?
    Laurence
    #255329
    Re: Frigidaire Fridgemaster F/F MTRF222 Stat?
    Hi Laurence
    yes you can use a standard VT9,If I remember correctly connect the grey wire which is to the lamp power to the live in and use 4&6 tags.
    Also remove the plastic disc that is on the evaperator liner before refitting the new stat.
    Bryan
