I think I need to remove the front panel on a Bosch Classix 1200 to get to the heater element and then to a bra wire trapped between the inner and outer drum. The question is how to remove the front panel, already have control panel and door removed.
Before you do this ,and if you havn’t done it already , run your hand all over the inside of the drum. A lot of times , the end of the bra wire may still be poking through a hole in the drum and its possible to pull it out using pliers !
