Frost and cold fill valves
Home Forums General Trade Forum Frost and cold fill valves
  • #61102
    silverbroom
    Order up you cold fill valves now. If the weather forecast is right for this weekend it’s back to sna and freezing temps.
    Those cold fill valves we fitted a wee while ago are about to go again.
    silverbroom
    #344861
    DDSDDS
    Re: Frost and cold fill valves
    GOOD STUFF
    what a terrible part such a waste of time and other peoples money
    #344862
    Specialist01269
    Better off in our pockets than the punters, 😆 but I won’t hold my breath for the calls to come rolling in. Only had 1 pop in the last lot.
    #344863
    rolf
    silverbroom wrote Those cold fill valves we fitted a wee while ago are about to go again.
    Mrs Townsend will be on her third one this winter if thats the case. First one went in December second in January.
    I do find a good freeze is good for business though. All them frozen pipes lovley jubbly.
    Its a bit like when it rains the Mrs says what you smiling for . I say ” They will all be putting there tumble dryers on now. Kerching” 😀
    #344864
    A1TEC
    Had the same guy in dec and jan, machine in garage so look forward to anothe double valve. 😆
    John.
    #344865
    cornflakes
    had a tip from my supplier wrap valve in bubble wrap and cable tie
    its just like lagging pipes
    pity frost has gone will have to wait to see it it works
    #344866
    RocketMan
    Cornflakes, that might help a little. What I see happening is the supply hose is starting to freeze as it’s external to appliance and even touching an external brick wall. More often or not I see the ridgid parts of the hose gives way first or in tandum with the valve. The flexible part of the hose can cope with a small amount of expansion. I may be wrong….
    However, I have had a good amount of work removing machines from garages and shoe horning them into kitchens. All in all a very good earner that last cold spell 😀 😀 😀 😀
    I did run out of valves and had to do a certain amount of re-use of second hand/old parts (with the agreement of customers). I also nearly ran out of hoses at one stage until I re-stocked.
    #344867
    gandh1
    cornflakes wrote:had a tip from my supplier wrap valve in bubble wrap and cable tie
    how will THAT get you any repeat business, apart from anyhting else is well in addition to manufacturers orginal specs 🙂
    but seriously, its not worth it, its little gain, if the customer cannot be fuzzckled to turn their taps off in the garage/shed once theyve finished using it, let them pay, im had my fill of stupid/ignorant/iknowbetterthanyou people to last my lifetime…
    #344868
    silverbroom
    Well up here the cald snap came to nothing but as meh granny used tae say ” ne’re cast a cloot till May be oot”
    silverbroom
