Frost Free Samsung Fridge Freezer RL39 WBSW Fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Frost Free Samsung Fridge Freezer RL39 WBSW Fault
  • #79088
    tepidmoss
    Samasung
    • Model RL39 WBSW
    • Serial 848341AX700091B, Model Code RL39WSBWI/XEU
    Fridge Freezer stopped working, food had started to defrost. Power was still on but no humming from compressor.
    On switching power off and on again the unit started working again and got up to temprature freezing the food. However the following morning the unit had stopped working again.
    I tried defrosting the unit but the same thing happend again.
    I have replaced the Freezer Thermostat and Defrost Thermostat but there is still no change?
    Notes, Both sides of the unit get hot to the touch when freezer is switched off and on again to get to temprature. The freezer evaporator freezes up when on. Fan works fine. If i change the temprature on the controls the compessor starts up again?
    Anybody got any ideas please?
    #407855
    Re: Frost Free Samsung Fridge Freezer RL39 WBSW Fault
    Most likely cause is the defrost heater and or thermal fuse.
    Bryan
    #407856
    tepidmoss
    Is the thermal fuse easy to find please?
    Im guessing the defrost heater is behind the evaporator?
    Thank you for your help.
    #407857
    yes the evaporator and is behind the panel. And the heater is on the evaperator and the thermal fuse is also attached to the evaperator
    Bryan
    #407858
    tepidmoss
    Is the evaporator conected via a flexible pipe alowing for it to be moved? Thanks for your help Bryan.
    #407859
    No
    #407860
    tepidmoss
    Hi Bryan,
    Please can you tell me if this is the right part please?
    http://www.buyspares.co.uk/defrost-heat … ost+HeateR
    #407861
    Does it state for a RL39 ? I can’t see on my phone
    #407862
    tepidmoss
    No it doesnt fit, is it not possible to get the heater without purchasing the whole Evaporator Assembly?
    #407863
    I have the correct part in stock e mail me samsung@ffrservices.co.uk and I will reply after Saturday
    Bryan
