Re: Frozen Veg in Crisper of Hotpoint FF Fridge/Freezer FFA7
if heavy frost/ice uniform on back poss module but had a couple of diverter valves block allowing cooling on freezer only cycles.
not sure how much modules are. prob best to get hpt out…
FYI tho they run on fuzzy logic. i.e. they switch comprssor and diverter on and off to factory defaults until it saves a better on off pattern to attain the selected temps.. if you get me… it uses this then if a thermistor fails to carry on as normal, but it cant tell if thermistor drifts…
cheers recall
