Has anyone had this fault, it seems pretty generic but it happens half way through the final spin cycle. no other details as it happens intermittently. hope you can help
Re: Fuse blowing on control board GW708U F&P Washer
Given that the problem is intermittant and only on the spin sequence, I would suggest investigating the wiring loom to the motor and Rotor position sensor. This is prone to corrosion and chaffing problems at the bottom of the drum.
Curious – done a bit of digging in the tech info – only phase 1 machines are fitted with a circuit protection fuse. Yours is a phase 4, so I’m not sure what to make of that.
