Fuse for F&P smartdrive 701
  • #21094
    ekol
    What amp size is the fuse on the subject washer?
    #189493
    Re: Fuse for F&P smartdrive 701
    The machine should draw about 3 amps max load, so a 5 amp for mains protection should be enough. There is also a 1.6 amp circuit protection fuse on the motor controller board. If this has blown, check out why – simply replacing the fuse will not solve the problem. Check out wiring at the motor and pump for chaffing and breakages, and for leaks in the same areas.
    Power off, of course.
