Re: FX1465W beeps 7 times
First check the outlet hose is not syphoning; when the machine has filled and starts to turn the drum, press ‘Pause’ and listen for running water. Also watch the water level; does it drop? If so; the outlet hose is either too low down or the end of the hose is pushed too far down the drain stand pipe and cannot air – break. Lift the hose and tie it up to prevent the hose dropping. The hose needs to be in the stand pipe about 6″ – 7″ only.
Post back if the problem persists……:wink:
Steve.
