G.D.A BF72 int’ D’W E8 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries G.D.A BF72 int’ D’W E8 fault
  • #13371
    Seamy
    Been asked to look at a mates G.D.A BF72 integrated dishwasher, he says it runs for a few mins then beeps & E8 is on display, don’t see it in the fault codes thread on here.
    #154536
    Re: G.D.A BF72 int’ D’W E8 fault
    Not sure on that specific model but if it is an Indesit heap. ALO8 on a similar DWF70 and DWM75 is a heater fault. The heater is very prone to failure on these and can be easily accessed and checked with the base off.
    #154537
    bendaireboy
    yep i had same fault it gave me two types of fault on same m/c 1.e8 code stopped after 2-3 mins or 2.kept running to end of cycle but everything cold 😀 hope this halps ta for meile hint
    #154538
    Seamy
    Its the type with the Black Cardboard type cover on top & down the back, heater is the thru flow type heater (adjacent to circ’ pump) as used mostly in whirlpool d’w’s,, are there any resettable cut-outs on this machine? I think there is a built in overheat device on heater from memory, can anyone confirm this
    #154539
    Dave_Conway
    This is a Smeg appliance, E8 is a fault with the water alternating valve (upper/lower spray arm) that sits next to the circ motor. 🙂
    Part number 1802035 at around £45 ex VAT if it proves faulty.
    #154540
    bendaireboy
    Seamy sorry to give you wrong gen!If it is Smeg as Dave say’s also check in sump to see if there is black rubber disk under filter to the rear of sump. if there is lift it up and clean up inside with bottle brush to remove possible blockage,as this not onlygives E8 but E2 fault code regards Bendaireboy [nige]
