Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › G2P DWI dishwasher problems can anyone help?
- This topic has 11 replies, 2 voices, and was last updated 16 years, 8 months ago by
coys2006.
August 11, 2009 at 9:16 pm #47734
coys2006
ParticipantHi all,
I’m new here and was hoping if someone could help me please. I have a G2P DWI dishwasher and have a problem with it. The machine starts the cycle and fills up with water but does not pump it out. When I stop the machine and reset the cycle, once I shut the door the pump kicks in and drains the water out of the machine before astarting the cycle again and filling up with water. As i know the pump etc works I’m assuming that it could be the flow switch isn’t showing a high level of water. The pump stops when it has emptied out so it must be switching a low level. Do you think it could be the switch or could it be the pcb?. Any help would be greatly appreciated. many thanks
August 12, 2009 at 11:06 pm #294400Penguin45
ParticipantRe: G2P DWI dishwasher problems can anyone help?
If it stops and beeps, count the flash pattern from the start LED – it’s an error code.
August 14, 2009 at 11:59 pm #294401Penguin45
coys2006 wrote:It doesn’t actually stop and beep throughout the cycle it just keeps filling up with water. I have to stop it myself and restart the cycle to get the drain pump to start and clear the water. I do remember it beeping and flashing though at one point with two flashes.
coys2006 wrote:I have taken the dishwasher out and removed the pressure switch. I’ve tested it and it’s working fine. I also removed the thermistor but it appears it is open circuit, I’ve placed it in hot water and the resistence has not changed. Although it looks like this may be faulty, I’m not sure how this could be the cause of the water not pumping out during cycle?.
Above messages received from Coys, I have removed any personal details. Can I please state for the record that this is a forum site; use the forums for questions and answers. I (and other UKW Trade members) do not have the time or the inclination to deal with every problem privately – it is unfair on us and to future users of the forums who may be able to find their answers using the Search facility on the site.
Based on what Coys has said, I suspect that we are looking at a fairly classic computer board problem. Select a programme, press start and runaway fill. If the computer were working properly, it would detect the water level through the flow meter count and the level switch. Failure with either of these will abort the programme (and the fill process). Failure of the temperature sensor will also generate an error code – machine beeps, drains and flashes its start light in an identifiable pattern. As this appliance does none of these things, it’s not a “logical” fault, thus implicating the computer board.
Penguin45,
Moderator.August 15, 2009 at 10:27 am #294402coys2006
Thankyou for all of your help, I’ll try changing the board and go from there.
Thanks Again
August 20, 2009 at 7:21 pm #294403coys2006
Hi all,
I have ordered a control board for the G2PDWI but it isn’t anywhere on the machine!!!!!!!!
I have located the user board at the top of the door but I can’t find the control board anywhere??????
If anyone could enlightem me I would appreciate it, thankyou
August 20, 2009 at 7:41 pm #294404Penguin45
coys2006 wrote:I have located the user board at the top of the door but I can’t find the control board anywhere??????
That’s the fella – does the lot.
August 20, 2009 at 7:45 pm #294405Penguin45
Hmm – three versions. Post up the 12nc number (starts with 8) and I’ll see if I can find you a part number.
August 20, 2009 at 8:45 pm #294406coys2006
From reading all of the posts I thought that there was a “user board” and a “main control board”.
Number on the module located in the door of my dishwasher is UCB-1CFD-P5-A2, which I assumed to be the user board.
i had a look on the spares website for a “main control board”, and found one but when it turned up I couldn’t find it anywhere on the machine. The code on this part is CB-Z0-V0-M3, and it obviously doesn’t look anything like the “user board”.I assume I have ordered the wrong part, is this for an older machine?
Paul
August 20, 2009 at 11:57 pm #294407Penguin45
Penguin45 wrote:Post up the 12nc number (starts with 8 )
Label – side of the door – it’s the only number which matters.
August 21, 2009 at 7:39 am #294408coys2006
its: 8542 347 15810
thanks
August 21, 2009 at 8:19 am #294409Penguin45
Part number should be 4812 218 38169.
August 22, 2009 at 12:13 pm #294410coys2006
Thanks, ordered the part and will try it out.
