Gaggenau EB270271
  • #62812
    franz
    Does anyone know what fault code F42 means?
    Franz
    #351390
    razor
    Re: Gaggenau EB270271
    found this doing a web search
    Open circuit in the door contact switch even if the door is locked.
    If this happened during a clean cycle sometimes if you start another cycle and then switch the selector off after a few seconds the fault will right itself. If this doesn’t work then you probable need a new door lock.Hope this help
    dont know if its right thou
    #351391
    franz
    Thanks Razor
