Gaggenau RB491200/43
  • #102037
    DPDOM
    Would anyone have a service manual for this please. It has a noisy fan in the fridge section and I’ve spent ages trying to get the Evaporator cover down without success.
    kaibart
    No service manual available but I can give you some advice on how to do it the 6 screws need to come out t20 then the earth wire behind and the wires need to be removed I’ve attached pic of 1st step,try and follow the steps in pics I’ve circled and arrowed most screws that need to be removed when you remove all the electrical components there is a metal bar that needs to be removed you use a pliers and pull it to the left to release it and then back to right to remove it then you should be able to access the fan which is held on with 4 screws. Hope this is some help to you kai.
    #487317
    kaibart
    Another pic
    #487318
    DPDOM
    Thank you so much for taking the time posting this info. This model was slightly different with lights in the cover and down the side so even more to remove but job done.
    Thanks again
    David
    #487319
    kaibart
    No worries glad it helped a bit for you
