[USER=”125″]don[/USER] you got any info on this ?
As far as I know you should not have much problem with a dedicated freezer outside. The main problem is with fridge freezers where the freezer is ccontrolled by the fridge temperature. These units can defrost the freezer if the outside temp stays around +1 degrees
the only other problem you may have is condensation. In the old days the thermostats were machanical so a bit of moisture was ok. These days of circuit boards mean water can be a killer
