Garment drying symbols
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Garment drying symbols
  • #95372
    Grocery365
    General query not related to any specific model but about the drying symbols on garments. Cotton garments have either one or two dots on the label. Can I still use the cotton drying cycle for those with one dot or is this too rigorous and/or too hot for those garments? Same applies to synthetic items. Some have one dot and some have two. Is the synthetic cycle too hot and /or too rigorous for those with one dot and if so what cycle would be appropriated? If so what cycle would be recommended instead?Mixed cycle – does this mean for an item of mixed fibres or a whole load containing a mixture of cotton and synthetics? Bed linen cycle – how does the machine know what fibre/temperature to dry it on so as not to damage the item as bed linen can be made of different fabrics and require different settings. For info I have an AEG Lavatherm 6000 series. Thanks in advance. Elaine
    #460168
    If in doubt always use the lower temperature, may need to run for a little longer though.
    #460169
    One dot = low heat.
    Two dots – high heat.
    You cannot dry items with one dot at the higher heat or you will damage them.
