Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Gas feed to cooker?
- This topic has 6 replies, 5 voices, and was last updated 14 years, 4 months ago by
alex123.
December 1, 2011 at 9:07 pm #66632
alex123
ParticipantHi any help appreciated to this question.
We’re buying a house without a cooker. There is a space in the kitchen, an electrical socket for a cooker. There is also a small (10-15mm diam.) copper pipe sticking out the wall about 100 mm above the skirting, projecting about 25mm, capped.
Q: Is this a gas feed??We’ve only ever had built in gas cookers before so don’t know what a gas feed looks like. I have a photo I can provide if req’d – couldn’t see a way to post this.
Cheers.
December 1, 2011 at 9:13 pm #364722adv
ParticipantRe: Gas feed to cooker?
a would think so but if your not qualified in gas a wouldnt touch it to be honest
December 1, 2011 at 10:52 pm #364723iadom
ModeratorRe: Gas feed to cooker?
“alex 123, I have a photo I can provide if req’d – couldn’t see a way to post this.
Below the ‘Post a reply’ box are two tabs, Options and Upload attachment.
Click upload attachment and then follow your nose. 😉
December 1, 2011 at 11:04 pm #364724kwatt
KeymasterRe: Gas feed to cooker?
That’s not available until you’ve hit a certain number of posts Jim to stop spammers uploading the rubbish that they’d like to. But if you email the photo to me or any of the other mods we can append it to the post.
But yes, it likely is a gas pipe that’s been capped. And, what adv said, it’s not worth chancing it with gas… tends to go off with a bang when it’s not done right.
December 2, 2011 at 9:46 am #364725alex123
Thanks all
I have NO intention of touching anything. Just need to know whether I can buy an electric or gas apliance. I’d prefer gas.
I’ll try to post the pic now
December 2, 2011 at 9:55 am #364726alex123
picture attached.
Property is late 60s as you can probably tell by the ‘original features’
Thanks everyone.
December 17, 2011 at 11:05 am #364727Mark_Fixcookers
That looks very likely to be a gas feed, however there will need to be remedial work on the pipework as it’s current termination point is too low to meet todays regulations. The gas safe registered engineer you hire to correct this will also be able to connect your has cooker should you buy one.
Also look above the point where the “hob” part of the appliance is going to be, if there is an electrical socket there, or anything inflammable, these are other concerns that will need to be addressed first
