Gas oven cant turn off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Gas oven cant turn off
  • #83311
    garyg1971
    I have a Whirlpool gas cooker, its old and I cant turn the knob to turn the oven off, it turns so far and then hits a stop. Help!!
    #422421
    Re: Gas oven cant turn off
    dont know why it wont turn but you dont want to leave it on so you can do one of 2 things
    1 turn all the gas off but i guess that would leave you without heating
    2 if there is a flexible pipe feeding the cooker they normally can be disconnected. its a bayonet type of fitting. its self sealing so there will be no problem. after that you will either need to find a gas cooker engineer or replace the cooker
    garyg1971
    Ok, turned off gas, turned gas back on so I have heating. Oven went out and as far as Im aware, it stops pumping out gas as a safety feature, Im just looking for a bit of expert knowledge, in case Im wrong
    #422423
    some of the later ones do. you have to hold the knob in for 30 secs otherwise it just goes out again. if you cant smell gas you should be ok but beware of pushing the knob in by accident
    garyg1971
    You have to push the knob in and turn it to the temp, when you push the knob in you can hear the gas, if you let go, it stops.
    Its an old cooker.
    #422425
    thats ok then
    garyg1971
    Is it easy to disconnect the cooker?
    #422427
    lee8
    Had a customer with that issue on a Kenwood range, he’d left it lit and kept filling baking tray with water for 48 hrs. Bit too hot to work on when l arrived.
    #422428
    ……..and he walked away, on to the next non job.
    #422429
    lee8
    Well yeah, after l capped of the supply. I don’t do repairs, haven’t for yrs.
