Gas pipe in new extension
Home Forums Public Support Forums General Enquiries And Questions Gas pipe in new extension
  • #15310
    oldfield_ian
    I am building an extension to my house which will include a new kitchen and utility. Is it usual / preferable / regs to have a new gas feed pipe installed below the floor, or should it be installed later? This is for the cooker and boiler.
    I am aware the work must be done by a Corgi engineer, but some advice at this stage would be helpful (ie. before I lay the concrete floors). Also, would the engineer nowadays install plastic or metal pipe?
    Thank you.
    Ian.
    #163031
    Re: Gas pipe in new extension
    Underground is not an option, exterior 22mm gas pipes are resin shielded for running along an outside wall. Inside the only option is across the roof space or between floors with plain copper pipework.
    #163032
    wsts
    Martin wrote:Underground is not an option, exterior 22mm gas pipes are resin shielded for running along an outside wall. Inside the only option is across the roof space or between floors with plain copper pipework.
    underground IS an option as long as you stick to the corgi guidelines.
