Home › Forums › General Trade Forum › gas safe
- This topic has 9 replies, 5 voices, and was last updated 6 years ago by
tash.
March 20, 2020 at 7:57 pm #97356
tash
Participantjust asking what the rules are on dual fuel ovens. i have replaced elements motors that involve removing the back but shy away from anything around the controls etc. i’m not gas safe registered. what does everyone else do?
March 20, 2020 at 9:45 pm #467209electrofix
Moderatorwelcome to the biggest grey area in this trade
i have always done it with the idea that as long as i do not remove any pipe going to or from a gas component then i could do it
we have long asked for some clarification as gas engineers are not always good at electrical faults
March 21, 2020 at 8:33 am #467210tash
Participantok that clarifies it haha. i think ill stick with my usual way just to be on the safe side .if i disturbed an already weak component on the gas side when stripping down . well just not worth the chance
March 21, 2020 at 1:20 pm #467211stratfordgirl
ParticipantOh well, link posting only seems to work at domain level, so here is the link in text:
https://www.gassaferegister.co.uk/media/1449/who-can-legally-work-on-a-gas-appliance-factsheet.pdf
March 21, 2020 at 1:43 pm #467212tash
Participantcheers that makes sense
March 21, 2020 at 2:29 pm #467213SAMURI
ParticipantRemember the last person to work on an appliance is responsible for it.
A gas safe test should be carried out after a repair as how do you know a leak was not there before you repaired it or if you have disturbed a joint while you repaired it.
if anything happened after you left how could you defend yourself in court.
You can still repair but get the customer to sign to say you have advised them to have a gas safety check before using.
Another way around it is for the customer disconnects the Appliance from the gas push fitting and reconnects it themselves and signs to say they have done it.
It then makes the customer responsible if they do not take your advice to have a gas safety check.
Better to be safe than sorry.
March 21, 2020 at 3:39 pm #467214kaibart
ModeratorThe customer can legally connect and dis connect a gas cooker as long as it In the 1st instant is done by a gas safe engineer. I personally don’t advise this as if the bayonet fitting is leaking which I’ve had a few times then you will get gas coming through
March 21, 2020 at 5:53 pm #467215SAMURI
ParticipantAs I said advise to have a gas safe test after it is reconnected and before using.
It is better to pass this type of work to a gas safe registered person.
It could save you a lot of hassle.
March 21, 2020 at 11:04 pm #467216kaibart
ModeratorI am gas safe that what’s set in stone
March 21, 2020 at 11:54 pm #467217SAMURI
ParticipantNo problem for you then plus you can charge more for a repair.
Gas safe appliance engineers are becoming a rare breed.
Keep safe in these worrying times
