Home › Forums › General Trade Forum › Gas Safe & Proud
- This topic has 11 replies, 7 voices, and was last updated 11 years, 7 months ago by
squadman.
August 26, 2014 at 10:26 pm #81981
squadman
ParticipantHow about this half wits work? and to think you need to gain qualifications to enable you to do this, and yes it was a Gas Safe Engineer that did it.
August 26, 2014 at 10:44 pm #418333kwatt
KeymasterRe: Gas Safe & Proud
It’s legal.
Not right. But still legal.
August 26, 2014 at 11:49 pm #418334stratfordgirl
ParticipantRe: Gas Safe & Proud
Possibly dictated by the customer on grounds of cost? I imagine routing the pipework to the rear of the dishwasher would have increased the gas fitting charge quite a lot, although more cost effective in the long run.
August 27, 2014 at 7:09 am #418335squadman
ParticipantGas Safe & Proud
Ah Cost, that’ll be it then, the upshot is that needless to say the appliance could not be repaired as it requires removal and now the gas engineer has been booked to come and remove the pipe so as to allow the removal of the appliance for which he is charging for!
I am having some trouble following the cost aspect. I have advised the customer that if the gas engineer is going to remove the pipe and then the dishwasher is repaired with him returning to put that pipe back where it is . That they get someone else to repair the dishwasher as in the event the dishwasher were to exhibit any future problems you just know the customer is gonna want the person who made the repairs to the dishwasher to foot the bill of the gas pipe issues.Thankfully we won’t be going back to this one I don’t need the bother of someone else’s problems.
Sent from my iPhone using TapatalkAugust 27, 2014 at 8:02 am #418336Martin
kwatt wrote:It’s legal.
Are you sure about that? That compromising and preventing the safe access to other electrical domestic appliances is legal?
August 27, 2014 at 8:16 am #418337kwatt
If it’s safe, it’s legal.
Doesn’t matter if it prevents you removing other stuff, even if it does seem like abject stupidity to us.
August 27, 2014 at 1:43 pm #418338lee8
How about this. Not so easy access & nowhere near the manufacturer instructions.
August 28, 2014 at 9:08 am #418339Martin
GasSafe wrote:
Dear MartinThank you for your correspondence.
In this instance I would refer you to BS6891 which states:
8: Installation
8.1 Installation pipework shall be physically protected or located where it is not liable to mechanical damage
If the customer has concerns relating to the gas safety of the installation then he/she can raise a complaint via 08004085500 Option 6 or enquiries@gassaferegister.co.uk .
John Stirling SIIRSM RSP EngTech MIGEM
Technical Support Officer
Gas Safe Register200 Cedarwood, Chineham Park, Crockford Lane, Basingstoke, Hampshire RG24 8WD
Tel: 0800 408 5500I would suggest in this instance that the pipework could indeed render itself “liable to mechanical damage” and Squadmans customer should report the guy using the complaints procedure shown in the email above. 🙁
August 28, 2014 at 9:44 pm #418340Sparrowhawk
Not only is the location wrong not to current standards, flexible gas pipe should hang downwards in a natural loop.
Sent from my Venue 8 Pro 5830 using TapatalkAugust 28, 2014 at 9:54 pm #418341kwatt
Martin wrote:I would suggest in this instance that the pipework could indeed render itself “liable to mechanical damage”
Only if you move something and disturb the pipework.
If you don’t, no problem.
I do agree, it’s as daft as daft can be and prevents or hinders access but that doesn’t make it illegal (at least technically), just daft.
But then, you don’t know what the customer asked for as I’d think that was an after the fact addition to the kitchen and it is all too possible or, even likely, that the customer opted not to have the expense of unit removal etc to do the job correctly. It’s pretty evident that that pipe was put there after the kitchen was in. So to save cash and a heap of hassle, you get this.
Would I be surprised if that proved to be the case? And, would I be surprised if they didn’t own up to that?
BTW, the answer to both is a resounding, not bl00dy likely.
August 29, 2014 at 12:33 pm #418342lee8
Sparrowhawk wrote:Not only is the location wrong not to current standards, flexible gas pipe should hang downwards in a natural loop.
The photo does not show it on the ground 😳My photo shows a pipe bent in a way that will cause it to break by simply being in that position without any external interference.
It’s the usual problem with gas safe, one persons interpretation of the regs against another’s, but Ken is right the pipe is not under any threat by being there, the regs are clear, if the pipe was being placed at risk without any interference it would be an issue. Same as gas pipes in the ground, perfectly safe until an idiot sticks a jcb through it.
Gas safe does not work by what if’s. The regs work on facts.
August 30, 2014 at 9:46 am #418343helo_75
hi guys , have you missed me?
lol.. the first picture is actually not quite up to spec, the pipes arent supported at a regular enough interval
and all bayonet attatchments must be easily accessible for the consumer
