GDA BF41
  • #15167
    DentedPorsche
    Hiyas,
    Does anyone have a parts diagram they can send me for this machine?
    I’m particulary looking at the sump/bowl area. The wash pump connects to tube that splits into two which in turn fits into the bowl. It’s this part and any seals it should have that I’m interested in.
    Also want to see the arrangement for the bottom spray arm, the machine I looked at the bottom spray arm isn’t held in at all, it just sits there and blows off when any water starts pumping through.
    Any help will be greatly appreciated.
    Brian
    #162460
    Re: GDA BF41
    its a valve 1801538 and the seals are:1801539 large and the 2 o rings are1801552. 1801547 is the new spray arm which should cure the other fault.
    #162461
    DentedPorsche
    Re: GDA BF41
    Spot on. Absolutely brilliant. Thanks for that.
    Thanks and regards
    Brian
