GDA BF71 dishwasher no fill
  • #55434
    talkingtent
    Please can anyone help I have a gda bf71 dishwasher this machine will not fill with water the main wash motor runs at the time when you select any program. Have checked inlet valve all ok and lower hose to sump all clear Any thing else to check ? Thanks
    #323669
    talkingtent
    Re: GDA BF71 dishwasher no fill
    Just to let you know this machine is made by Bosch with the solid base if that helps .
    #323670
    micro switch jammed by blocked or faulty float in left hand panel?
    #323671
    talkingtent
    Just to let you know the fault was the impellor had come apart so not pumping correctly !!
