GE fridge spares
Home Forums General Trade Forum GE fridge spares
  • #66642
    SAMURI
    Do anyone know if and where you can get GE American fridge / freezer spares ❓
    Bob
    #364746
    Re: GE fridge spares
    GDHA are now the UK agents.
    Good luck with that. 😉
    GE fridge spares
    What parts do you need ? I have plenty.
    Bryan
    #364748
    SAMURI
    Hi Brian the Model is not clear on the label but it is S25NGMFCBB7UK OR SG25NGMFCBB7UK THE PARTS REQUIRED The black drip tray in the water dispenser. Also the door stop at the bottom of the fridge door to stop the door opening too far it screws to the bottom of the door.
    I also need the water filter. I can sorce the filter but if you have the parts I will order the filter from you if you have one at the same time.If you have the parts let me Know
    Bob
    #364749
    GE fridge spares
    Will be back in the uk on tues hopefully pm me to remind me
    Bryan
    #364750
    DrDill
    Older GE get the parts from ISDAL, newer ones from GDHA and as Connect are an approved reseller for GDHA you can get the bits from them, or ring GDHA direct spares line, i use them all the time and they are very helpful and give you part numbers which work on connect sytem.
    #364751
    SAMURI
    Bob
    #364752
    SAMURI
    Hi Brian
    I have sent you a PM are you back yet.
    I hope you had a good time.
    Bob
    #364753
    Hi Bob
    message sent but the model you have should be a PSG25NGM.
    Bryan
