Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › GE: GSG20IEPAFBB. No water or Ice
- This topic has 6 replies, 4 voices, and was last updated 18 years, 9 months ago by
redesp351.
July 13, 2007 at 12:17 am #28960
redesp351
ParticipantHi all,
I have a GE side by side fridge / Freezer with 2 issues.
1. The water dispenser wont work. I have water flowing through the filter and to the coupling at the bottom of the door before it goes into the base of the door, but nothing at the dispenser.
Any ideas on how to clear it out or clean it??. The door itself appears to be a sealed unit and I can’t check the internal hose.2. The Ice maker keeps freezing up. ie. the motor that drives the Ice Dispenser freezes up and (obviously) won’t turn. I have to remove the motor, defrost it and then re-install it about once every 2 months.
I was contemplating surrounding the motor in some insulation material (poly foam or something similar) to stop moisture getting into the motor
Thanks for any feedback
July 13, 2007 at 7:06 am #220858admin
KeymasterRe: GE: GSG20IEPAFBB. No water or Ice
How old is your fridge freezer ?
the auger motor that dispenses ice will need a new motor and a cover that I have in stock or available from the on line shop.
It sounds like the insulation in your door has failed and is causing the water pipe to freeze.this isnt replaceable so its a new door im afraid.
Bryan
July 13, 2007 at 5:37 pm #220859Penguin45
ParticipantRe: GE: GSG20IEPAFBB. No water or Ice
Long way to Oz, Bryan………. 😀
:p45:
July 13, 2007 at 5:59 pm #220860admin
Hi Peng
He didnt put where he’s from…can still have the part anyway’s…loll
bryan
July 13, 2007 at 6:25 pm #220861Penguin45
“Australasian Appliance Forum” was a pretty broad hint. :rotl:
July 13, 2007 at 10:22 pm #220862redesp351
r600a wrote:Hi
Bryan
Thanks for the reply Bryan.
The unit is about 3 years old. I figured that the motor kept freezing up due to the temperaure in the Freezer. Won’t a new motor just freeze up to?
I have notices that the motor is located 1. below the Ice maker with a slotted cover (to keep it cold??) and 2. it is above the cold air recirculation fan and the cover is also slotted.
Maybe a combination of condensation and cold air blowing directly onto the motor. It was never going to be an overheating problem …lol.can you please post the link to your online shop.
As for the hose in the freezer door… well that remains a mystery and I’m not prepared to change the door.
Again. thanks for the adviceDave
July 16, 2007 at 7:59 am #220863bigsmokepiker
ModeratorRe: GE: GSG20IEPAFBB. No water or Ice
If only 3 Years Old Suggest you Contact the retailer
If you purchased thru Kleenmaid they have a 5 Year Parts & Labor Warranty
KLeenmaid 1800817479 ( OZ) -
