General Electrical American Fridge Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries General Electrical American Fridge Freezer
  • #74689
    S1MON
    PCG23mimhfbb
    DG401582
    The pipe that feeds the water nozzle located in the freezer door has spilt, it is leaking when dispensing water. The water tank in the fridge was frozen and I think the hose in the door has frozen at some point.
    Any ideas if you can pull the old pipe out and replace as the door is obsolete??? as there is no clear information to whether it is part of the door, I have given it a pull but want to makesure I can go back with a piece of replacement hose.
    #392524
    Re: General Electrical American Fridge Freezer
    pipe is foamed in and non replaceable. jnr
    new door im afraid
    #392525
    S1MON
    Balls…
    Cheers for the reply
    #392526
    SAMURI
    AWS now supply GE parts worth a try to see if a door can be obtained.
    Some MAYTAG fridge freezers have the same parts.
    If it is an older model look on E Bay some times you can come across good second hand parts
    I have obtained obsolete parts before on E Bay old stock etc.
    But a door may be hard to obtain.
    Bob
