Getting inside Hotpoint DWF32
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Getting inside Hotpoint DWF32
  • #46098
    Farside
    I need to replace a drain hose from my Hotpoint Aquarius DWF32 dishwasher but I can’t work out how to get inside the machine. I have trawled the internet looking for the answer but with no joy. I can’t work out where the access panel is.
    I am reluctant to call out an engineer for what will be a 5 minute job once I can access the pump.
    Any suggestions would be gratefully recieved.
    #288228
    Re: Getting inside Hotpoint DWF32
    Remove baskets, filters and bottom rotor. Bail out as much water as you can. There is a single Torx screw in the floor of the sump, at about the 11o’clock position. Remove it, then pull the tab sticking up towards you to remove the drain pump cover.
    pc7777
    ❓ hi , got a hole in the drain hose and need to replace it, but like the person above, can not see how to remove the top so i can get the side off, please can anybody help me, does it slide forward with a bit of force ❓
    #288230
    Two small lugs underneath the top at the back, push these in with a flat bladed screwdriver and then push top forwards.
    #288231
    pc7777
    #288232
    Seamy
    Bit of advise, stay outside 😀 you’ll only get drenched when it starts up !
